Ok I have this problem with nero when burning. SCSI/IDE Command aborted
This is what I have read from neros site on the problem.
http://www.nero.com/en/helptool/229.htm
This awnser in particular I think may be my problem.
"Please check if there is a program accessing the burner. Please deactivate the option switch off the automatic to be deactivated for the drives. In particular if the error message only occurs actually during the burning process and not during the simulation."
That is exactly what happens it works during simulation but gives me the error when I actually write.
I don't think it is the automatic to be deactivate thing as I have XP.
I am on Xp SP1. I am using an NEC ND-1510A inside a Bytec external enclosure connected with USB 2.0
So what could be the problem? What other programs could be accessing my burner? Could it be the Safely Remove Hardware program that XP uses to determine if you can safely remove the hardware?
Thanks guys.
Results 1 to 1 of 1
Burning Using External LG BP 06LU10 Problem
By bruuce in forum DVD & Blu-ray WritersReplies: 1Last Post: 23rd Aug 2011, 18:56 -
AVStoDVD 2.3.2 - Process aborted during DVD Burning Operations
By Mark97213 in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2010, 14:05 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 15:54 -
External case for my BenQ W1640
By bluemoss in forum DVD & Blu-ray WritersReplies: 7Last Post: 15th Nov 2007, 15:09 -
What IDE to use to create a simple GUI for command line tool?
By freebird73717 in forum ProgrammingReplies: 10Last Post: 5th Nov 2007, 13:51
