Hi
I want buy a dvd recorder With Hdd,
the Pana write the dvd-r and dvd ram mode VR
the jvc write the dvd-r, dvd ram and dvd-rw mode video and Vr
the best format for editing on a pc: Dvd ram with Pana
or Dvd ram, Dvd-rw in video mode or Vr with a JVC?
A other + for the Pana is the Reader card memory.
it's very difficult for the choice!.....
Can you help me
thanks
Dominique
DVD-Video format is easier and faster to deal with on the computer for editing and re-authoring. Plus, finalized DVD-Video discs are much more compatible with regular DVD players (very few can play back VR format discs). The JVC also gives you the advantage of recording to DVD-RW's, so you won't need to worry about getting a DVD-ROM that can read DVD-RAM discs, either. Finally, the JVC makes a better looking MPEG2 recording than the Panasonics do because of the "DigiPure" video enhancing and noise reduction filtering that occurs prior to encoding.
I have used Panasonics for 3 years and was happy with them until I used the JVC, I'll never go back. The picture is noticably better on the JVC, although a little softer than Panasonic. The JVC also has more options for setup than the Panasonic. One of the biggest advantages for me is the JVC records all usuable space on a DVD-R giving approximately 2hrs 14min in SP, the Panasonic stops at 2hrs with the outside edge of the disc left unused.
On a Panasonic with a Harddrive, if you use the high speed dub option to dub from the HD to a disc, you can use all of the disc space (~2:13 min in SP mode). It treats the disc like a data disc in this type of dub. It works great for putting 3 x 1 hour TV episodes on 1 disc after editing commercials (assuming the edited episodes are ~42-44 minutes).
The limitation to 4 gb of disc space only appears on real time, direct to disc recordings. -
thank for your posts
i wait my jvc MH30 from germany, i hope that is the good choice for me.
I will post here my first rewiews
Dominique
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
JVC GZ-HD6 camera mode very bad?
By steve_rb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 28th Dec 2009, 09:49 -
JVC GR-D850U Randomly Goes into SnapShot Mode
By cj18370 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Nov 2009, 10:42 -
Panasonic AG-W1 stops when in PAL play mode.....
By ubbm in forum Newbie / General discussionsReplies: 1Last Post: 5th Sep 2009, 17:39 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14
