I used virtualdubmod to change a .ogm file into avi but it made it 20GB. and thats alot of room for a 30 minute video. it should be nowhere near that. why is it that big? is there a way to make it smaller and did I just do it wrong?
thanks alot for any help that is given
you probobly didn't select a compression type and made it an uncomprressed avi
try again and pick what codec you want to use .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
dvd players play mpeg files -- you didnt say you were making a dvd ..
virtualdub doesnt make mpg files either ... you need a mpeg encoder , then author your dvd , then burn it ..
btw - your friend is wrong , dvd players ONLY play compressed files ...
mpeg is ocmpressed , some players also play some types of xvid and divx files , which are also compressed ..
see some of the guides to the left to get you started .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
umm 2 questions though about changing them to a mpeg file. which do I use there are different types of them. and also will I be able to set it up so that it can be in either language and have subtitles on them when I want to. I want to be able to burn all 3 of those to the dvd and then be able to choose how I want to listen to it.
EDIT: oh I guess by author that means I can? lol sry for all the questions i dont really know that much about dvd players and such. never really messed with them before -
start reading some guides
compressing video filesize for storage
By azor in forum Video ConversionReplies: 18Last Post: 18th May 2011, 02:34 -
Problem with target filesize in xvid
By legion0 in forum Video ConversionReplies: 18Last Post: 22nd Mar 2010, 00:58 -
Reducing Filesize of .avi
By jonesb in forum Newbie / General discussionsReplies: 5Last Post: 4th May 2009, 12:01 -
Reduce VOB filesize
By jacktorrance in forum Video ConversionReplies: 8Last Post: 14th Jan 2009, 12:34 -
Reducing filesize
By caper in forum Video ConversionReplies: 19Last Post: 7th Dec 2008, 20:22
