I have a Leadtek WinFast DV2000 TV card & using the WinFast PVR Tuner/capture software.
I have tuned many TV channels, but even though the picture & colour quality is great & the motion is synchronized with the audio, the channel frame rate seems to be just a bit slower & sluggish, compared to a real TV.
It’s not terrible but the motion isn’t as natural as my real TV.
I live in Europe & all tuned channels are PAL.
I checked the settings of the card & software, but I didn’t find any option to fix this.
My system:
P4 2.4GHZ
768MBRAM PC800
GeForce4 Ti4200 128MB
SB Live 5.1
WinXP PRO SP1
Also...
What’s the best Bitrate mode to choose, when capturing from a TV-Antenna signal into mpeg2 codec?
Variable Bitrate
Or…
Constant Bitrate?
I don’t want to lose any frames or witness jerkiness in the final video.
Also I’m thinking about capturing in this resolution: 720x576 PAL
Any ideas?
Thanks in advance.
Jerkiness is either 1) dropped frames or 2) deinterlace
Both are bad.Want my help? Ask here! (not via PM!)
How can you tell the difference?
I think it's a case of deinterlace.
How do I fix it?
I just checked.
Yes overlay mode is enabled & there is another option: "Closed Captioning" which is not checked.
But they're both "grey" & can't change them even if I wanted to?!
Hhmm...?
Also "time shifting quality setting" is set to optimal quality. -
Is this happening on the PC screen view or in the captured file??
If on the PC screen view it may be that the screen refresh is too slow causing a slow frame rate effect. If the PC screen is OK and the capture files are strange it may well be dropped frames..
Frame rate rule of thumb .. 720 x 576 5Meg bits should be Ok..
Best PQ as possible via external tuner? Bypassing internal tuner/processor.
By Wizard256 in forum Capturing and VCRReplies: 0Last Post: 24th Jan 2010, 22:39 -
tv tuner
By maryhigginsrice in forum Newbie / General discussionsReplies: 7Last Post: 17th Dec 2008, 18:07 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / IPTVReplies: 0Last Post: 7th Jun 2008, 01:42 -
TV Tuner Help!
By anony283 in forum Capturing and VCRReplies: 13Last Post: 30th Apr 2008, 09:30 -
High Definition TV? Tuner or no Tuner?
By aturjans in forum DVB / IPTVReplies: 6Last Post: 17th Mar 2008, 07:31
