i need a router as my bt modem is messing my asus motherboard up even with a powered usb hub .(runs for a time then blue screen and reboots, something to do with usb ,the only thing on usb is modem. it will work fine for days on end if not on net)
has any one got any ideas which one £20 to £150 , ilike the sound off the
Vigor 2500 by DrayTek at @£107 ish any one got one ? any good ?![]()
can any one help ?
Why not just get a usb to ethernet converter?
They aren't very expensive. -
where do you get them from in the uk most of the sites say discontued
A deal, even better.
Nothing can stop me now, 'cause I don't care anymore. -
I have the draytek (wireless version) that is the best router you can buy.
GET ONE NOW !!!!
N router
By jyeh74 in forum Off topicReplies: 0Last Post: 30th Mar 2012, 21:35 -
Getting A New Router
By Tom Saurus in forum ComputerReplies: 17Last Post: 11th Nov 2011, 16:42 -
Need a new Router.
By Poppa_Meth in forum ComputerReplies: 10Last Post: 29th Sep 2008, 05:50 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 12:34 -
Managed Router
By SIRCOOKS in forum ComputerReplies: 11Last Post: 24th May 2007, 12:15
