Hi. I used to do analog video capturing with an old PixelView TVExcel Analog TV Tuner, now I've upgraded to the Nebula DigiTV model. I bought this product for the double benefit of receiving DVB-T signals (SD & HD) as well as having the analog video capture facility. I am running an Athlon64 2800+ alongside a Powercolor Radeon 9800 Pro with plenty of RAM and HD.
Currently though, I am having trouble selecting my preferred "Data Format" from the "Set custom format" menu item in VirtualDub (of which this particular option is not available within any other program like AVI_IO, iuVCR etc). When I used to run the older TV Tuner card, I could select something like the preferred YUY2 when choosing the "Frame size" (resolution) for capturing analog video on the composite/SVideo connectors. Now that I'm on the Nebula DigiTV device, I can only select the (apparently) wasteful RGB24 setting - all of the other options are right there for me to choose from, but everything except RGB24 is coming up with the dreaded "Error 418: Unsupported video Format" error. It doesn't matter which codec I want to use either (be it HuffYUV, MJPEG or even Uncompressed RGB), so it's definitely not related to the type of compression being used (or is it?).
Now, unless I have to activate some trivial setting within Windows or even modify something in the Registry to make YUY2 (and every other "Data format" option) available for selection, then I have no idea what I am doing right or wrong. Can someone please help me try to get this working? Thanks heaps. WG.
Results 1 to 1 of 1
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
Suggestion needed to select my capture device
By syedmahm in forum Capturing and VCRReplies: 18Last Post: 6th Sep 2010, 15:48 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53
