Assuming there are no other factors to be considered, what are the differences in compression between [.mp3], [.mp2], & [.ac3]?
If I have a 128 kb/s [.mp3] file, what audio bitrate should I use to maintain audio quality if I am to convert to:
[.ac3]:
[.mp2]:
Hello,
It's not that simple. AC3 and MP2 are SPECIFICALLY for video. MP3 is music. Go with ac3 for the best compatibility, regardless of compression rates.
If I go to [.ac3] (for DVD), what bitrate would you suggest if the original [.mp3] is 128 kb/s?
Hello,
Well for ac3 most REAL movies use 384kbps (that's for dolby digital - Star Wars and others use 448). I've had some dvds made by a friend from a home dvd recorder (settop model). It uses 256. I guess 256kbps would be ideal.
Kevin
P.S. Sorry if I have the kilobits per second abbreviation wrong, you get my point though.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
?? Mostly used in Video DVD, yes, but that's all.Originally Posted by yoda313
There exist no such bit rate, as every reencode reduces the quality (when using lossy codecs like AC3 or MP2). The higher the bit rate, the more like the original, but never 100%If I have a 128 kb/s [.mp3] file, what audio bitrate should I use to maintain audio quality if I am to convert to:
[.ac3]:
[.mp2]:
/Mats -
I think whenever people ask this type of question, they are mainly asking at what point will it be overkill. Yes, with both video & audio, there is going to be some subjectivity based on your personal satisfaction standards. If you really like a particular show, anime, movie, etc., you'll want to know what's the absolute best quality you can achieve; i.e. you'll be picky. But if you don't care as much about something else, you'll (very naturally) regard less quality as acceptable even if you are trying to achieve - let's say, dvd quality both times.
However, there have to be general rules. For example, encoding from clean Mpeg4 sources, it has been determined that it can be from about 3-6 times the original bitrate when encoding to Mpeg2. This helps set some guidelines. There must then be a way to determine how to maintain quality from [.mp3] sources when encoding to the [.ac3] & [.mp2] formats.
There is a way to determine overkill for video using the Constant Quantize method of encoding. Is there some similar encoding method with [.mp2] & [.ac3] encoders?
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 00:46 -
mp3 -> ac3
By cL0N31 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Apr 2009, 21:26 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
Looking for simple software that will convert mp2 mpa to mp3
By jimdagys in forum AudioReplies: 23Last Post: 20th May 2008, 08:26
