What it the best resolution for converting dvd to xvid ?
Hello,
If you leave it on the pc go as high as you have space for. For cd-r I think a 1pass at 750 or so should do for most 2 hour movies.
Kevin
P.S. Look here and select video bit rate calculator - those will give you a good idea.
https://www.videohelp.com/toolsDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Heya,
No offense but I believe the question was regarding resolution not bit-rate.
I convert my DVDs to DivX and halve the resolution from 720x576 to 352x288. I have found that DivX videos I have downloaded with high resolutions play jerky on my "TV-out PC"(P3 450Ghz).
I am also interested in what resolutions people encode DVD > DivX / XviD. What do the experts do? -
I use 640x480 for full screen stuff. For widescreen I usually use 640 by whatever it takes to get the picture height at the proper aspect ratio, usually around 288. I usually inverse telecine (NTSC) to 24 fps if necessary (and possible).
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
