I posted this in an appropriate thread, but it went ignored ...
Everyone speaks of how creating chapters is incredibly easy with VideoPack. While this is true, I have yet to encounter an mpeg that gives me accurate chapter stops. So, I read the help and found this:
The specifications specify that a marking must be integrated in permissible MPEG material approximately every 0.5 seconds (sequence header) that represents a jump point. If the MPEG material has not been created in accordance with the standard, it can be that these markings are missing or are too far apart. However, only these markings can be used as jump.
So, I figured I needed to reprocess to the mpegs to get these "markings" in the proper places. I tried MPEGCorrecter, VCDGear, and iFilmEdit with no success. How do I get these "markings" to appear in my mpeg files? It seems pathetic that VideoPack doesn't do this for you and offers no potential solution sources.
Since originally posting this, I've tried numerous pieces of software to "correct" or to "demux/remux" but nothing seems to work. There has to be a way to process an MPEG and get these "markings" in there.
Thanks for any help.
das
You should specify the number of GOP's to which a sequence header is inserted. This option you will find at the GOP settings of your favorite encoder.
When the Videopack manual says "approximately every 0.5 seconds", it expect a sequence header before each GOP and a GOP length 12 (IBBPBBPBBPBB)for PAL resp. 15 (IBBPBBPBBPBBPBB)for NTSC.
If you have encoded the MPEG alreaddy, you may try to insert the sequence headers with MPEG Sequence maker. Demultiplex the mpg, run the m2v through that tool and remultiplex.
<font size=-1>[ This Message was edited by: Truman on 2001-11-20 19:11:17 ]</font> -
Hey, thanks for the quick response. I'll try that right now. Forgive me if this is a "newbie" question.
das
Help calculation seconds from Time Code.
By lberezinski in forum ProgrammingReplies: 2Last Post: 30th Mar 2010, 12:53 -
time difference between audio and video after capture till tens of seconds
By dekelbeitar in forum Capturing and VCRReplies: 0Last Post: 7th May 2009, 10:11 -
Trimming a few seconds of SD from a HD MPEG-2
By silentg in forum EditingReplies: 7Last Post: 10th Nov 2008, 15:46 -
Add 6 seconds to the start of an AVI
By jcww_88 in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2008, 07:14 -
Add seconds on to track?
By sbuckmybballs in forum AudioReplies: 4Last Post: 23rd Dec 2007, 20:35
