I want to make a disc only with the extras from others discs and i have 4:3 (mostly) and 16:9 extras. What soft should i use for authoring?
Tanks in advance for all that read/reply me
Hello,
If they're seperate clips it doesn't matter. The only problem becomes when you try to MERGE them. But you could easily use most dvd authoring programs to add each clip as a seperate video then structure it to play the next one automatically, no reencoding needed.
If you want to merge them into one clip you could use tmpgenc and force it to be full screen.
DVD Lab Pro
Allows multiple VTS - each VTS will have it's own video attributes.-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Yes, what you need is multiple VTS support, DVD Lab Pro will do it, as awlchu posted
Thanks yoda313 and awlchu,
I just ask this cause i tried with DVd Lab and it says at its F1 HELP that's just possible if i:
put the 4:3 like motion menus (no chapters)
OR
re-encode 16:9 to 4:3 with tmpgenc
But now i'll go check out DVD LAB PRO, thanks -
please try post in correct forum. moving you to the DVD authoring forum.
or use tmpgenc dvd author, add new track and you can mix 4:3 and 16:9.
Recording & dubbing to disc.
By waspbill in forum DVD RippingReplies: 5Last Post: 6th Apr 2011, 01:08 -
convert avi with subtitle files (.sub & .idx) into .m4v with soft subs?
By The Nemesis in forum Video ConversionReplies: 1Last Post: 6th Mar 2011, 21:40 -
Hardsubs to Soft Subs & Other Questions
By Startropic1 in forum SubtitleReplies: 2Last Post: 12th Apr 2010, 13:30 -
Encoding & burning to Disc
By wst959526 in forum Video ConversionReplies: 1Last Post: 8th Jul 2008, 15:44 -
Free soft for burning DVD LightScribe Disc
By fjmr in forum MediaReplies: 4Last Post: 1st Dec 2007, 23:01
