i open my file in TMPGEnc, but the audio does not show up. i open the file in GSPOT and this is what it said
VVVVVVVVVVVVVV
GSPOT
video format
codec
4dd DX50 name DivX 5.0
status codec IS Installed (details...)
audio format
stream codec
1> name divx (same as wma) (0x0161) DivX Networks
what does this mean? do i need a codec? if someone can send me the codec that would be great
thanks![]()
extract the audio to wav with virtualdub or avi2wav and use it as audio source in tmpgenc.
www.videohelp.com/tmpgenc#problems -
i just tryed VirtualDub-1.5.10 and it said i dont have the right codecs. then it said make sure u have the microsoft audio codecs installedOriginally Posted by Baldrick
what should i do? -
Try AVIcodec. Under 'codecs and filters', check 'audio'. Down the list you should see, 0x0161 Windows Media Audio V2, Version 4.2.0 (or similar).
I believe this is standard audio codec for windows. If you don't have it, you might check Microsoft and see if you can find it there.
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 07:40 -
Codec problems with mov, mp4 and wmv
By lyrd in forum LinuxReplies: 15Last Post: 29th Jul 2008, 15:30 -
Codec problems via website only ?
By yukon33 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 15:19 -
Codec Problems
By Armadillo in forum Video ConversionReplies: 7Last Post: 12th Dec 2007, 13:42 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 09:56
