  1. Hi all!
    How can I fit nearly 4 hours of SVCD contents onto a single DVD with menus?
    I've read something about "re-encoding" in DVD format, but it will then require 2 DVDs. The SVCD quality is fine for me because they are VHS-captured cartoon episodes (they are more than 30, thus I really need menus). The simple video files would fit into the DVD since they are 3.76 GB all (five distinct smaller ones): I hope it's only a matter of authoring software.
    I'm using WinDVD Creator 2 at the moment.
    Thanks for any tip!
  2. nanifra,
    You can find guides for authoring SVCD to DVD here:
    https://www.videohelp.com/author#3;29
    I would reccommend this guide:
    https://www.videohelp.com/guides.php?guideid=266&howtoselect=3;29#266
    That will allow you to author SVCD to DVD without re-encoding. It may be possible for you, or it may not. I believe it depends on the player.
    If that fails, try this:
    https://www.videohelp.com/guides.php?guideid=391&howtoselect=3;29#391
    Best of luck!
    Cobra
  3. THANKS!!!!
    Going to try
    NaniFra
  4. You can just put your clips straight into tmpgenc dvd author, author and then burn with your favourite program, I use nero 6 ultra.
    If it's wet, drink it
    My DVD Collection
  5. Thanks Hardcoreruss: will try!
