  1. latly when i try to encode xvid to dvd with tmpgenc 3.0 express i get this error.......
    Invalid sample format. (error code 0x80048002)
    i can't figure out why. it seems to be doing this with every xvid i try to encode. can anyone tell me what this is being caused by?
    thx
    SITH
    USA
    Check the XVID with AVIcodec. You may have AC3 VBR audio, which can be a problem with TMPGEnc.
    I use the freeware program TheFilmMachine for XVID to DVD. Works very well for me.
  3. ima try the film machine. ill get back to you.
  4. i get a bad sync problem with this software. i wish i could figure out the tmpgenc express problem. it didn't used to do this, it started a few weeks ago and i can't figure out why.
