I'm very familiar with the old adage 'crap in, crap out' but here goes..
Usual avi source is 480x480 or 480x576, div3 low/fast motion, with the film being split over 2 files averaging 200MB per avi. Also these are dvd rips not screeners etc.
I usually use TMPGEnc plus and more recently xpress, but I have have always been plagued with a certain degree of blockiness in the outputted mpeg file. The source avis usually have very little blockiness when compared to the end product, so I was wondering was there an ideal set of output options to at least reduce this blockiness?
For example is there an ideal resolution to output these avis, considering the source resolutions I mentioned, as I have always used 720x576 as standard?
Also are there any other settings (in xpress preferably) that I can tweak to improve the overall quality? Seems no matter how high the bitrate I use it does little to improve the quality.
Encoding time isn't really a big deal and specs-wise I use a P4 3.2HT with 512MB RAM.
Thanks.
You're upsizing your video, that's the problem. You cannot "create" a higher resolution without causing problems. You should be encoding to 352x480/576. Try it, I think you'll notice a difference.
"Art is making something out of nothing and selling it." - Frank Zappa -
Funny resolutions for avi encodings.....they look like mpeg2 (svcd) resolutions that some idiot has directly converted to avi (divx3).........not surprising that you get blockiness the avi's are way off to start (you aint got any horizontal res).I'm very familiar with the old adage 'crap in, crap out' but here goes..
Usual avi source is 480x480 or 480x576, div3 low/fast motion -
As u noticed, the avis use the svcd resolutions but, if this makes any difference, they were intended for svcd output, it's just I prefer DVD. Mainly due to quality, but also I can't be bothered with the extra hassle of splitting films across 2-3 discs when 1 DVD will do the job.Funny resolutions for avi encodings.....they look like mpeg2 (svcd) resolutions that some idiot has directly converted to avi (divx3).........not surprising that you get blockiness the avi's are way off to start (you aint got any horizontal res).
I tried dropping the resolution to 352x480/576, and it made a slight improvement, but the real difference came when i started using noise removal, to differing degrees. Only downside is that it takes 4-5 times as long to encode with TMPGEnc using these filters.
Also you said the avis were 'way off', so is there anything I can do to correct them or is the damage done? If poss could u explain what u meant by 'you aint got any horizontal res'?
ps - Source avi is always NTSC but I output to PAL as my DVD player doesnt accept anything but 25fps (and i live in a PAL region)
Converting YV12 to anything else causes inexplicable blockiness
By Asterra in forum Capturing and VCRReplies: 13Last Post: 19th Apr 2011, 06:02 -
m2ts to xvid or h264 always gets blockiness
By ubulord in forum Video ConversionReplies: 29Last Post: 24th Dec 2010, 12:18 -
Blockiness in a running water scene
By Umen Pich in forum Video ConversionReplies: 10Last Post: 20th Nov 2008, 10:32 -
Bigger factor for blockiness/compression artifcats
By pannayar in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:47 -
Help with reducing size
By gepetto in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 13:17
