I just got a new computer, so I need to load the latest video codecs for it. I know there used to be a codec pack that had a bunch of the codecs in it. I can't seem to find that, however. Is there one big pack that includes most of the video codecs, or do I just need to look for the latest version of each of them individually?
Thanks in advance.
There are several codec packs which include the most common codecs, usually they are not recommended. Having conflicting codecs can be a frustrating experience. To answer your question, you should only install the codecs that you need to decode your files. Use Gspot or avicodec to test your files and install the audio and video codecs as needed.
Best way to install popular codecs
By snafubaby in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2011, 06:30 -
What codecs should I install? Which are the best?
By DonGallego28 in forum Newbie / General discussionsReplies: 29Last Post: 22nd Sep 2009, 12:23 -
can't play rm in mplayer on mac osx--did install reallib codecs
By onesuch in forum MacReplies: 2Last Post: 20th Dec 2007, 00:56 -
Does SimpleDivX install its own versions of codecs?
By Toastie in forum DVD RippingReplies: 0Last Post: 1st Sep 2007, 15:23 -
Codecs - Which to install on fresh OS?
By acommuter in forum Newbie / General discussionsReplies: 9Last Post: 7th Jul 2007, 16:39
