i have a video file that's svcd compliant in terms of video, but not audio. according to nero, the audio play at a frequency of 48,000 Hz, so i need to convert it to 44,100 Hz, correct? so i demultiplexed the file using tmpgenc and used besweet to downsample the mp2 file at 48,000 Hz to 44,100 Hz (no, i didn't convert the audio format - it's mp2 to mp2). now when i attempt to multiplex the new mp2 file with the video, tmgenc says the audio file is "illegial."
i noticed that after downsampling, the size of the mp2 file shrunk signficantly - from approximately 75 MB to 45 MB. is this right? i find it hard to believe that frequency plays that much of a role in determining the audio file's size.
perhaps i didn't configure besweet properly. if you can tell me how to do it properly, then please reply with the instructions.
thanks in advance.
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 17:33 -
downsampling MKV
By saimike in forum EditingReplies: 1Last Post: 6th May 2009, 12:08 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
Downsampling H.264 and splitting
By alfista in forum Newbie / General discussionsReplies: 0Last Post: 2nd Aug 2007, 06:55
