Any help would be appreciated!! I am using the divx 3.11alpha codec and VirtualDub 1.4c.
In order to fit a divx movie onto cd, I cut the credits off the end, but lately it has not worked. During playback the sound disappears about 32% the way in. I am using direct stream vid/audio. I have tried VD 1.47 but, it is worse with the screen jumping and audio totally off sync.
To experiment, I have cut smaller 5 min clips off Shrek.divx and Swordfish.divx, and have found that about 32% into the movie or clip, the sound disappears!! The beginning up until this point is perfect, but as soon as it gets to about 32%, the sound stops working.
Any suggestions would help,
thanks,
>vandalaybay
Results 1 to 1 of 1
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 04:47 -
Using Mencoder to Cut Commercials from TS/TP fils not working
By Randall_C in forum Video ConversionReplies: 0Last Post: 3rd Jul 2010, 16:47 -
Final Cut HD templates are not working.
By Tom in HD in forum MacReplies: 7Last Post: 30th Sep 2008, 21:33 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 18:39 -
DivX player not working
By davecc in forum MacReplies: 3Last Post: 12th Jun 2007, 20:15
