  1. I am starting the process of converting all my dvd's to xvid and I had a question about the quality settings. I am converting so that I can keep all my movies on the hard drive, but without losing much quality. I converted the same movie useing 100% quality, and max 2000mb file size. The 100% quality setting produced a file that was only 1.8Gb so my question is is the 2GB file wasting the last 200 megs?
    Hunting, sure i'll go hunting. When is cow season?
  2. After reading this myself a day later I understand I may need a little clarification. What I did was I converted this movie 2 times, once with 100% quality, and once with a 2000 MB file limit. Now I understand that because im converting this to another format that there will be some quality loss, and im ok with that. I have viewed both of these on my tv and they both look great. However, my tv is only a 19inch and I plan on upgrading in the future and dont really want to have to convert all these twice if the quality isn't going to be that great on a bigger screen. So really i have four questions.
    1. Is autoGK bloating the file to make it 2000MB or is there actually a difference in the quality.
    2. Does anyone that has a bigger screen (ie 36inch) have experience with the quality of these settings and does it look good?
    The 2000MB video is 1:39:04, 704X288, 23fps, audio is 448Kbps AC3 and Video is 344Kbps XVID
    The 100% video is 1:39:04, 704X288, 23fps, audio is 448Kbps AC3 and Video is 310Kbps XVID
    3. Is encoding a longer movie (maybe 30minutes longer, think your average length movie) going to reduce the quality alot?
    4. If these settings are too low what would be a better setting?
