hey, i was wondering something, i have an external dvd burner, but since my pc doesn't have USB 2.0, the burning take about 2-3 hours, and i was wondering, since its an external burner, should just leave the computer alone while its burning? or is it safe to go on? cause it takes a long time, and i want to go online![]()
You don't mention in your profile which CPU you have. Asuming your CPU is fairly fast and, just as importantly, your HD is modern and it and your MB have decent transfer rates, you should be fine. No doubt you have buffer underrun protection and you're probably already utilizing it since your burns take that long. That's about 1/2 to 1/3X
Typical for a burn across a USB1.1 interface.
I'd say you're transfer is being limited by the USB and not the CPU or HD, so you should be safe enough multitasking while burning
BTW I like your username
If i was you I would invest in a USB 2.0 card well worth the money and your sanity.
You could always remove the drive from its external housing and install it inside your computer, as it's just a normal ATAPI drive anyhows, and speed up the burning process dramatically if you don't want to buy the card...
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Are you running your burner off your USB 1.1 ports? or Firewire?Originally Posted by Invader Bugs
If 1.1 I'm suprised the burns don't fail on you. If you drive supports a Fwire connetor go spend the $25.00 for a 1394 card... you'll be so happy when you get a 15-30 minute burn.
How to tell active codec?
By The111 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2009, 06:19 -
Active Buttons on DVD Menu
By dartmanx in forum Authoring (DVD)Replies: 1Last Post: 22nd Jun 2009, 04:53 -
Adobe Premiere Elements 4.0 Active Camera effect
By kingstinky in forum EditingReplies: 0Last Post: 4th Jan 2009, 17:22 -
always black borders even though full zoom is active
By magmo in forum Blu-ray RippingReplies: 3Last Post: 31st Dec 2008, 02:50 -
Automatically open WinDV when DV device becomes active
By jabloomf1230 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Jun 2007, 22:30
