  1. I have an MPEG that half way through it repeats the first half of the movie
    (audio) and also plays its current audio. can someone help me so i could get rid of the looping audio problem?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could demultiplex the audio (strip out the audio). Use tmpgenc and go to file-mpeg tools-demultiplex. Load the mpeg. Double click the audio file and save it seperately. Then go to the wizard and choose vcd or dvd (your format of the mpeg) and input the original mpeg as the video - and then the split audio file as the audio.
    Then process the two files together. Hopefully that should correct the problem.
    Kevin
    P.S. If that doesn't work you could try virtualdubmpeg2 and fool around with the audio tools.
