Hi
How can i join two avi files with diferent frame rates?
I have try with virtualdub but it give me an error and dont let me join
Anyone can help me??
Sure, change the framerate of one of them. Even if you could join them, I'm not sure if anything could play the file without locking up at the framerate change.
You can use Vdub to change the framerate.
"Art is making something out of nothing and selling it." - Frank Zappa -
sorry it was wrong my information
is not the framerate but the audio stream thas is diferent and it can join the two files.
Audio Streams
17624 - 17789
Any one can help me? -
If you change the audio in each file to wav then you will be able to join them. Load each file in Vdub, set video to direct stream copy, set audio to full processing then save avi. The files wil be a lot bigger due to the uncompressed audio.
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 03:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Easy way to join 2+ AVI files
By AppzBeWarez in forum EditingReplies: 2Last Post: 7th May 2009, 23:48 -
Join AVI files together ?
By terryfox in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2009, 22:56 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
