I've been using the same make of blank DVDs for ages now and never had a problem until today ,its my last 4 DVDs and they didn't want to work and (MEDIUM ERROR ) kept coming up.
I then went on to choose 2xDVD burning speed in toast6 and it worked fine but does that mean i have to burn all my DVDs in 2x now instead of best or 4x.
I don't understand what went wrong.
Any help in this matter would be greatly appreciated.
thanks scott.
TAKE IT,BUT TAKE IT EASYYYY....
More information would be helpful. What kind, brand/media code, of DVDs are you using? What brand/model number DVD burner do you have?
agreed.... what drive do you have? what media are you using?
My 4x media recommendation is Ritek -
Its a pioneer internal(mac) DVDburner and my DVDs are a brand called PRINCO 4X.
I don't understand why6 they worked before though?TAKE IT,BUT TAKE IT EASYYYY.... -
PRINCO is a pretty cheap crappy media type - just to say they worked before and dont now can be a flaw in teh spindle you have such that a segment is defective disks
my only recommendation would be to get a better brand - more reliable ones -
What makes of DVD-Rs would you recommend, rememeber i live in tenerife and the choice is limited.
Cheers for the advice though.
scottTAKE IT,BUT TAKE IT EASYYYY.... -
In that case, can you give me a site to a place you can buy from?
Basically anything but PRINCO - they are the most inexpensive manufactured disks i can think of!
My favorites are TDK [which there is aparently 4x disks now], Ritek, Vertabim and Samsung
Thats about all I have really used
Strange BD Rebuilder problem - Output files too small??
By YBS1 in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 19:20 -
RCA small wonder problem.
By PK00 in forum Newbie / General discussionsReplies: 8Last Post: 5th May 2009, 15:15 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Burning small movie clips from camera(SD card) to dvd
By wesburnsco86 in forum Authoring (DVD)Replies: 6Last Post: 22nd Jul 2007, 15:09 -
Small problem psp 2.81
By the posse in forum ffmpegX general discussionReplies: 0Last Post: 7th May 2007, 15:52
