When I use standard VCD template to record a show from VHS to ATI Tuner. the result appears grainy.
If I was to use a higher bit rate to caputer the VHS info, would the picture look better?
Short story..can I make a poor picture look better with a higher bit rate?
You can improve the quality of your finished product using some of the templates for tmp in the tools section on the left. It won't look any better than what you started with, though. Tibro's works pretty well for me, I use it on some pretty worn out tapes and they don't look any worse on vcd.
Liz
Improve a old VHS Capture
By cd090580 in forum RestorationReplies: 1Last Post: 5th Nov 2011, 15:33 -
improve old VHS
By mathmax in forum RestorationReplies: 108Last Post: 2nd Nov 2011, 13:43 -
Improve 15 year old VHS quality when capturing
By diegolaz in forum Capturing and VCRReplies: 6Last Post: 12th Jul 2009, 15:17 -
VHS to DVD - is there any way I can improve quality of conversion?
By rairjordan in forum Capturing and VCRReplies: 21Last Post: 13th Feb 2009, 13:32 -
How to improve dark VHS picture?
By rbatty11 in forum RestorationReplies: 15Last Post: 11th Sep 2007, 19:57
