Home users that have their preferences set to receive operating-system updates as they are made available by Microsoft may be surprised to learn that some of the software they already run on their systems could be disabled by SP2 or may run very differently.
Many of the programs on Microsoft's list of problems will affect enterprise users for the most part. However, a big group of computer games, including a range of those made by Atari, are affected. In addition, the update can interfere with the operation of several popular antivirus programs -- including those made by McAfee and Symantec (Nasdaq: SYMC - news).
Be careful!!
Results 1 to 30 of 33
Good advice. Thanks
I heard that SP2 will turn Windows Firewall ON by default. And if the firewall is disabled, windows will keep nagging you until you turn it on again.
This will be a problem for me as im connected to the internet through a router (Netgear). The router has its own hardware firewall (always on by default, no option to turn off) so there will be conflict with the windows firewall. i mey even be left without a internet connection.
Guess i wont be updating to SP2. -
No.
It's not a problem.
I am connected through a router with a hardware firewall.
Even with the firewall on, I still was on the net.
I turned off the windows firewall though.
If you turn off the security center, then it will not nag you to turn the firewall back on. -
Wasn't going to get SP2 anyway until I absolutely had too. Hell, I only just install SP1...
running a hardware and software firewall wont cause you to drop connection. The software firewall with notify you if there are outgoing connections that you do not know are occuring. Unlike a hardware firewall they do not block all connection outgoing from your PC that seem legit but could be suspicious activity ie work trojan ext.
Originally Posted by Wetmonkey
microsoft firewall does not block outgoing connections (it was built for MS by blackice i understand)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
The SP2 upgrade went "almost" smoothly for me. Here are my random thoughts:
1) Adobe Premiere Pro 1.5 would not load after SP2 was installed. I had to uninstall other software that had installed 3rd party codecs, until PP would load. Apparently SP2 rearranges the priority of the audio and video codecs in some fashion and PP is very sensitive to codec priority. Thanks to the Adobe PP forum for the tip. This problem is obviously PC configuration specific and not a fault of PP or SP2.
2) The SP2 popup blocker is great.
3) The SP2 DEP (Data Execution Prevention) security upgrade didn't cause me any problems, but various Internet forums have threads about this problem. It's easy to turn DEP off, either for all non executables, or program by program. If your favorite program doesn't run, XP will display an error message about memory violation, etc.
4) You now get the official version of DirectX 9.0C, for what it's worth.
5) I also uninstalled McAfee Firewall, since there is no need for it. -
gitreel, thanks for the reply. but im going to hold off just a little longer before i install SP2.
That is cool.
I would hold off if I were you as well.
I tested it with my programs first b4 I installed it on my two computers.
I used it on a test machine. -
Haven't seen any problems yet.
3.141592653589793238462643383279502884197169399375 105820974944 -
Thanks gitreel....
how big is this puppy ? i heard something like 200 meg ?
Quick Info
File Name:
WindowsXP-KB835935-SP2-ENU.exe
Download Size:
272391 KB
Date Published:
8/10/2004
Version:
SP2Nothing can stop me now, 'cause I don't care anymore. -
Here's the list of potential problem programs.
http://support.microsoft.com/default.aspx?kbid=884130&product=windowsxpsp2Still a few bugs in the system... -
With my luck , it would screw up the ATI install . It only took me 3 years
to get that working . -
What's even more amusing is on the list of programs known to have issues with SP2 are many Microsoft programs like Office, Outlook, etc.Originally Posted by chas0039
Steve -
The only problem I have is that when I wake my computer up for hiberation, I get a warning "limited or no connectivity to network" The only way to fix this is to pull the modem out of my laptop.
A friend of mine can't even install SP2, his 100% legal copy of XP Pro will no longer connect to the domain after running any updates in the v5 updater.
Just have him click on my link from earlier in this thread.
He can download and install from there. -
I was thinking the same thing.Originally Posted by FOO
SP2 (from all the feedback) seems to be a huge danger to the stuff that is already in the PC. MS chose a simple, sledgehammer approach, "kill'em all and we have no problem". All those companies that laudly demanded that MS fixes things beware. You got what you wanted. Looks like WinXP will be the last man standing (haven't they just invented a new way of eliminating competition?) Watch out, if they missed you with SP2 they will get you with SP3.
Its 266 mb.Originally Posted by BJ_MI think,therefore i am a hamster.
Yep,
Read my thread in the Computer forum about the 200 apps.
How to proceed?
By fatcharlie in forum Video ConversionReplies: 4Last Post: 5th Apr 2011, 21:15 -
DVD Video made with PiTiVi and DeVeDe -- no sound. How do I proceed?
By VanillaMozilla in forum EditingReplies: 8Last Post: 7th Mar 2011, 11:02 -
PGCDemux/DGIndex audio delay report -- how to proceed?
By Gew in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2011, 03:22 -
Aussies thinking of buying computer gear online, CAUTION.
By blinky88 in forum ComputerReplies: 1Last Post: 29th May 2009, 03:03 -
vdub virtualdub No Video Not sure how to proceed
By case310350 in forum EditingReplies: 2Last Post: 4th Jan 2009, 21:31
