Hi ....
I am trying to make up a live music compilation. All the files I am using are .mpgs, but some are PAL and some are NTSC. Will that make any difference when burning them with Nero?
Also, using TMPGenc, almost all of them are ok, apart from a couple that comes up with error message on trying to open the file "could not open or unsupported". I checked using AVIcodec which says "V Codec name = MPEG2 (SVCD/DVD) ..... A1 Codec name = MPEG-1 Audio layer 2 (0xc0)" ....
It's weird because Windows Media Player / DivX Player plays the files no problem .... just hiccups when I want to put it into TMPGenc to encode it ...
Any ideas at all are greatly appreciated.
Thanks in advance
Ian
Hi again .....
I downloaded an mpeg-2 codec which made no difference to trying to get tmpgenc to open the file (it still won't open) ....
I opened it using virtualdub (mpeg-2) and if I want to convert that to an avi, then back to mpg, it will take up more space as an avi than my hard drive has got space for!
Hellllllp lol -
That's whay you frameserve, it feeds the video direct from one program to the other. Guide here.Originally Posted by CaptainChaos
You should be able to mix PAL and NTSC if you're making a DVD, you will need to add them as seperate tracks however."Art is making something out of nothing and selling it." - Frank Zappa
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
