Thread: Verbatim 94495 Media
  1. #1
    Member suppafreak's Avatar
    Jul 2004
    Posts
    178
    Hello.
    I am using the Plextor 708A DVD burner and looking to buy the DVD-R printable media. I am thinking to buy Verbatim 94495 DVD-Rs from here:
    http://www.meritline.com/verbatim-4x-dvd-r-dvdr-printable-blank-media-disc-discs-cake-box.html
    Can any one tell if you had a chance to use it and what kind of experience you had with the discs, good or bad? Also what media code these discs might have. Hopefully they are not CMCs. According to the Meritline website they are under the Professional Grade.
    Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Posts
    7,255
    Thats kinda expensive. I'd just go by some TYs from RIMA.
    Jul 2004
    Posts
    178
    The reason I want to get these is because they can be printed all the way to the HUB.
    Banned
    Jul 2004
    Posts
    61
    Yes , www.meritline.com is the best website. And I usually bought from www.cdrdvdrmedia.com
  1. AccountKiller
    By rcvalle in forum Media
    Last Post: 21st Dec 2010, 12:41
  2. Is there a website that can tell me if my Verbatim media is authentic?
    By rakan in forum Newbie / General discussions
    Last Post: 8th Feb 2010, 20:22
  3. Verbatim DL media
    By Krispy Kritter in forum Media
    Last Post: 4th Apr 2008, 11:40
  4. Verbatim DL media....$23.99 after rebate
    Last Post: 21st Dec 2007, 21:54
  5. Verbatim DL media...
    Last Post: 2nd Sep 2007, 21:29
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
