Results 1 to 13 of 13
  1. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    another strange question.
    while playing Catchphrase (which I highly recommend) with some friends, the term "lime dickey" came up.
    none of the 6 of us had ever heard the phrase, and so far Google and Wikipedia have turned up nothing.
    anyone got any info for me?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  2. Anonymous
    Guest
    This ought to get good.
    There is a bird called a Dickey,maybe it is a lime green one.
  3. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    sounds almost like cockney, but can't think what the real words would be....
  4. Still trying to figure out what that is
  5. Member Treebeard's Avatar
    Aug 2002
    Some sort of alcholic drink I think.
  6. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Treebeard -
    found that same link, but if you notice, that picture is only referenced in the html code - it doesn't actually appear on the page.
    I've looked in a couple of bartender's guides in the Housepig library, and no "lime dickey" yet...
    ... a mystery ....
    - housepig
    Housepig Records
    out now:
  7. Member Treebeard's Avatar
    Aug 2002
    The picture is there, if your screen is not set wide enough it will be pushed to the bottom of the page. I too went to some mixed drink websites and did not find lime dickey. I swear I have heard of it before but Im drawing a blank as to where or when.
  8. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    Try "Virgin Margarita"!
  9. Sound's like a Brittish term to me.
    "Terminated!" :firing:
  10. Irish maybe?
  11. Mod Neophyte redwudz's Avatar
    USA
    Check 'lime rickey' , an alcoholic drink, and you will find lots of references. Maybe a typo or some modification of the original drink?
