OK..... I have been tryin to do this for a looooooooong time and couldnt figure out somethin that worked...dunno why I didn't try this sooner...
U need:
AviSynth 2.54 (what i used)
VFAPI Convertor 1.05
https://www.videohelp.com/readavs-vdr.zip (allows VFAPI to load VirtualDub & AviSynth scripts)
MainConcept - u can download the demo.... don't ask... just read
also
FitCD (to generate AviSynth scripts if u r lazy like me
Ok.... if u got them all installed..... load the source file (AVI, MPG, whateva) in FitCD and set up your destination file up as u wish....
or
write your AviSynth script....
Make sure your AviSynth works properly..... try and open it and see if it looks like u want....
then load up VFAPI Convertor and click add job and open your AviSynth script.... (I usually do video and audio seperate so I turn off the audio when the options pop up) u can name your output file and leave the rest enabled....
convert it! it should take a few seconds (sometime it DOES generate a whole new file but this loadable as well dunno why it does that
load MainConcept or whatever MPEG encoder u use... and load your new AVI file VFAPI created and u are set!!!
I'm no guru but I thought this might help someone... feel free to rewrite it just give me a small credit somewhere![]()
Oh yeah left out a step... u might want to install
before u try to open a AVS file otherwise VFAPI wont be able to read it
Sorry
Frameserve from Premiere CS4 to MainConcept Reference
By nharikrishna in forum EditingReplies: 5Last Post: 13th Dec 2011, 21:42 -
Post deleted since I figured it out
By denise4gb in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2008, 22:29 -
Figured Out 'RATATOUILLE', menus and all
By theizzlesin2005 in forum DVD RippingReplies: 39Last Post: 11th Feb 2008, 08:48 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38 -
anyone figured out apocalypto yet?
By steamedPS in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 14:06
