  1. Hi everybody!
    I hope to be in the right section I have one question to do:
    I have recorded from TV a program complete of andvertisment and so on on my dvd recorder so I have a DVD with vob file and so on, I'd like to edit this video to cut out the part that i don't need and re-encode and burn on a DVD what is the best way to do that?
    thanks in advance haltman
    Mar 2003
    Uranus
    The best way I know of is to use MPEGVCR to edit and then
    re-author with TDA.
  3. You could use Chopper XP which cuts a VOB directly and outputs a VOB.
    This is not as precise as demuxing and editing then re-authoring but it is quick. I've tried it twice and did not have any sync problems.
    It wasn't me.
  4. Excuse me what is TDA
    thanks!
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
  6. Hi!
    I have noted that my video on source DVD is splitted in 4 files of 900Mb, it is better to join the 4 files in one and so cut out not needed parts and so burn it or i must work with the original 4 files separated?
    Thanks in advance haltman
