This is the first problem I have had with Sizzle 0.1....
I'm trying to create a DVD with 3 chapters, Sizzle stops(just sits there with the progress bar not moving) generating tracks files at 36.7%.
I've retried 3 times.
any augestions?
thanks
i havent tried any of the Sizzle updates.....never seemed to work for me.
the files you are loading into sizzle, they play fine?
what was your source files? -
pretty sure they play fine.
its a svcd that i authored to a dvd.
so, 3 m2v's, and 3 mp2's.
everything done exactly how you explain on your site.
this is the first time i'm had this problem.
and i've done it many times.
thanks
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Sizzle help
By danielmak in forum MacReplies: 3Last Post: 3rd Mar 2010, 07:37 -
Dealing with VOBs, subtitles, Sizzle and Miyu
By silverspell in forum MacReplies: 4Last Post: 25th Feb 2009, 06:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
How do I do this with Sizzle (dvd authoring tool)?
By master_debator in forum MacReplies: 0Last Post: 27th Aug 2007, 13:45
