Hi,
has anybody an idea which dvd-player will play discs from the states and also europe (region 1/NTSC + region 2/PAL) as well as SVCD?
Hajo
Hello Robbins
thank you for your information, but unfortunately I forgot to mention the dvd-player has to run in the states. Or do you have any information this player will work with an NTSC-TV attached to?
Hajo -
AFAIK that player plays ntsc and pal.
But since your in the states i don't think it would be worth your while buying a player from the uk.
David -
Get the Daewoo DVG-3000N, AMAZING DVD with tons of compatibility for under $100. Available @ Amazon.com
You will have to use the secret code to get multi region which you can find @ http://www.nerd-out.com/forum/
Playing a Region2 dvd on a Region1 Player
By barbudo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Feb 2011, 09:48 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 16:52 -
entire disc rip Drilbit Taylor Region1
By greenapple in forum DVD RippingReplies: 1Last Post: 13th Jul 2008, 04:09 -
Region1 disc... need to backup to region 0
By snadge in forum DVD RippingReplies: 11Last Post: 1st Mar 2008, 14:25 -
Region1 discs playback problem
By efiste2 in forum Newbie / General discussionsReplies: 12Last Post: 29th Oct 2007, 13:43
