  1. Hi
    I have loads of live music clips I want to put onto one cd-r ... I am currently TMPGenc'ing them, some of them are PAL, some of them are NTSC ....
    When I come to burn them onto cd-r, using Nero, does it matter? Should I specify NTSC or PAL prior to burning? What is the best way to do it?
    Ian
  2. Are you talking about svcd clips?
    Anyway, some dvdplayers have the ability to play mpg files so why not just burn them all in data mode and see if it works? It is just a CD-R, right?
    10110101100111012011 <- The bug Bill doesn't talk about.
  3. Hi ....
    They are .mpg files that I have "encoded" using TMPGenc and I intend to make a vcd out of them.
    If I try to just import them straight into Nero vcd, it tries to reencode them & comes up with "oh no you cant do that because of this" which happens with the TMPGenc encoded ones too, but it makes no difference if I ignore the "warning".
    I am more concerned that when I try to make a vcd, it asks if it is NTSC or PAL & if I have a mixture, it will distort it or make it run twice as fast etc etc .... if that makes sense?
    Cheers,
    Ian
