    Jul 2004
    I have make a movie on my computer and save it as .avi, and the other as .mpg.
    The movie is very long and I can't burn it as a DVD, so I save the movie as a data storate on my DVD-R.
    I was wondering how can I watch my .avi/.mpg on my DVD-R on my TV?
    Do I need any hardware or software? please help
    canada
    You need to buy a dvd player that has the features to play raw mpg and or avi,check to the left under lists which players can do this.The other choice is a graphics card which has video out.
  3. You could also still make a DVD out of it. Just author it and then use DVD Shrink to make it fit a DVD.
    Apr 2004
    Miskatonic U
    How long is it ? You should be able to fit 2 hours of pretty high quality video on a single sided/single layer disc, and up to 4 hours of better than VHS quality.
    Jul 2004
    johns0 - I have a Panasonic / Sony that does not have the raw feature. only can play mp3.
    "The other choice is a graphics card which has video out." So I can play the movie from my computer?
    guns1inger - about 3.5 hrs, I don't want to loose the quality.
    Is there a hardware device that play avi/mpg dvd data storage?
    Jul 2004
    no devices?
    canada
    Check on the left where it has dvd players and look for the ones that can play avi.
