ok this is what i did.
i used isobuster to extract two mpegs out of two separate svcd's. then i merged them with tmpgenc (v2.521) . then i used tmpgenc dvd author to author them on a dvd and it said that the GOP is too long but if it is xdvd format to just ignore that so i did. but then when i go to output the file to dvd files, it says that the resolution is 480 x 576 and that it cannot be used for standard dvd.
what should i do? should i resize it? how would i do it anyways?
or should i use another authoring program that would allow it. i tried to use ulead movie factory but i dont like it too much because it takes forever and its only the trial.
whats the best thing to do here? im still being introduced to new generation video editing/dvd making so please bear with me.![]()
SVCD video is not DVD compliant, you can either burn it to DVD and hope that it works on your player (for some it does) or re-encode it to a valid resolution like 352x576. Lots of guides right here.
DVD to MPEG Conversion
By Exodus119 in forum Video ConversionReplies: 2Last Post: 26th Feb 2010, 19:06 -
MPEG to DVD VIDEO-TS conversion
By efiste2 in forum Video ConversionReplies: 4Last Post: 7th Jun 2009, 16:08 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
Quicktime to Windows MOV-mpeg-4 conversion problems?
By Simone in forum ffmpegX general discussionReplies: 4Last Post: 16th Jun 2007, 06:50
