  1. Member garman's Avatar
    Sep 2001
    Guantanamo Bay, Cuba
    Wondering if anybody knows of a firmware to adjust the timer settings. I would like a mon-fri setting. The "daily" settings are a little too much. Every weekend I have to remove the disk from the tray. -garman
  2. Member DTSL06's Avatar
    Dec 2003
    Canada
    I also have a daytek and was wondering if the LiteOn 5001 FW will work since the Daytek is oem'd by liteon and basically the same as the 5001 inside.
  3. Member garman's Avatar
    Sep 2001
    I do recall somewhere, that it was done. Do a little search on daytek -garman
  4. I have the LiteOn5001 - none of their firmware support Mon-Friday recording. Only Once, Weekly, Daily. Sucks.
    That's why I use my Pioneer for Mon-Fri. Plus, the Pioneer has 32 timer slots.
    TJD
    LDW 5001, Nov 2003. Pioneer DVR-220-s, May 2004. Haup PVR-250 (2) Ver. 15 + 16. Slowpoke P4 1.8Ghz, 500 gig . Dish DVR-510 - 100 hrs. DirecTV RCA. DLP HD HT Projector at 170 Inches Diag. Tivo Gen. 1 with 180 hours
