  1. Ok, follow the newbie guide to create bin and cue files, and everything preceeding that. Everything has worked fine so far, split the movie into 2 mpegs (for 2 discs) and made a bin and cue for each one. I used CDRWIN to burn each disk, but when I put the disk in the drive (I have 2, a DVD and a burner) each either shows nothing at all, or gives an error about disk might be corrupted, unsupported format. I can't even browse the contents of each disk. I don't have a standalone DVD player to test it on, but I'm guessing it won't read either. HELP!!
    Any feedback is greatly appreciated,
    "The Newb"
    Scott Hudson
  2. Well men u forget something u need a burning program witch suports VCD and (or)SVCD ,cdrwin does not suport vcd so there s your problem .
    Use nero and you l see a miracle.
  3. First of all, if you read Sefy's article, you'll see that CDRWIN "IS" supported, or he would have left it out of the guide. Thanks for the uneducated response, and work on your english.
  4. Scott I'm with on the Guide. I tryed it also.But if you could load NERO you will have much better luck. I dumped it myself and went with NERO. Too many problems. Good luck.
  5. How did you create the Bin/Cue files ? and have you tried burning using one of the other supported programs, and NO, do NOT burn Cue/Bin files with NERO! the resulting burn will NOT work on a DVD Player.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
