i have a mpegtv 878 and i upgraded my windows to sp2 but for some reason i get the blue screen and a memory dump when i try to capture video through my ulead dvd software. Now i went to kworld website to see if there were updated drivers for the card but it seems like they have renamed the products the closest i could find was the pvr-878 but windows says this is not the right drivers. Does anyone have this card and windows xp and got it to work properly?
thanks
Is it the KWorld TV878RF-PRO or similar?
Have you tried loading the WDM drivers?
http://btwincap.sourceforge.net/download.html -
yes thats the exact model. have you tried upgrading the drivers? i will try the wdm drivers.
thanks -
No as I don't own one. If the problem persists you may havehave you tried upgrading the drivers?
to disable your cap card under hardware manager, reboot, remove
card, reboot, install card and then install a claen copy of your original
drivers. This might work if the SP2 install damaged your driver setup. -
I have this card. A typical bt8xx one.
Btwincap gonna give you top quality but usually those drivers don't handle the tuner well.
For capturing with this card, I suggest virtualvcr, not ulead!La Linea by Osvaldo Cavandoli
kworld dvd maker 2 help
By itsicon in forum Capturing and VCRReplies: 39Last Post: 18th Dec 2010, 11:21 -
Still having driver problems with windows 7
By intheory in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2010, 19:18 -
Help With DVD Driver? Firmware? unknown burning problems..
By spongecake in forum Newbie / General discussionsReplies: 7Last Post: 16th Jun 2008, 17:17 -
How to use Kworld DVDMaker USB 2.0
By barryblizzard in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2008, 10:21 -
Kworld ATSC 110 Problems
By Robert Simandl in forum DVB / IPTVReplies: 0Last Post: 2nd Sep 2007, 11:37
