Results 1 to 14 of 14
  1. Is there any good software out there to clean up my system registry a bit. I use to use Nuts and Bolts several years ago and every so often I could use it to get rid of a bunch of old registry entries no longer in use. I haven't used any such programming since moving to XP. So is it even beneficial to do something like this?
  2. Banned
    Apr 2001
    Calgary, Canada
    Norton WinDoctor (part of SystemWorks) seems to do an acceptable job, imo.
    Is it beneficial to do this? Who knows. Do I care if there are invalid entries in my registry? Not really, i reinstall Windows every 4-6 months anyhow
  3. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I have used RegSeeker for the last year and it seems to work great. It doesn't require any registry entries of it's own (nice) and it makes a backup of the registry keys it cleans up. It's free. Here's a link:
    http://www.snapfiles.com/get/regseeker.html
  4. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Ditto Norton WinDoctor. Good app.
    For adware/spyware Spybot Search and Destroy works well, and if it can't fix the registry entry you can highlight it, right-click, and it'll take you right to the registry key for editing
  5. Can WinDoctor be installed seperate from the rest of System Works? Thanks for the input so far guys.
  6. Banned
    Apr 2001
    Calgary, Canada
    Norton WinDoctor is actually part of Norton Utilities (which comes with Systemworks).
    On my Systemworks CD, there is an NU directory. In there is a Setup.exe. I ran that, and as expected it runs Norton Utilities Setup. Choosing a custom installation...
    So yeah, it can be installed separately
  7. thanks I'll give it a go. Might wait a bit though. I think my computer has gotten so full of conflicting softwares that its about time for a complete reformat and reinstall.
  8. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I think if you need the other stuff that comes with SystemWorks it may be worth the $70. For just registry cleaning I still recommend RegSeeker (free) or Registry Mechanic ($30) from the Winguides Tweak people. Free trial available.
    http://www.winguides.com/regmech/
  9. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I like RegCleaner. It's free, very powerful and no need to install. Just run the exe. I've used it on 98, W2K and XP. Works great!
  10. Yeah I'm thinking of trying RegSeeker as well.
  11. jv16powertools also includes a reg cleaner app, i forgot the name, but you can also purcahse it separately.
  12. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I prefer the registry cleanup tool called "format" myself.
  13. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    I tried that once and none of my programs worked. I couldn't even get into Window$.
    Nothing can stop me now, 'cause I don't care anymore.
  14. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I believe they purchased the rights to RegClnr which used to be freeware. Now they charge for it. It was a good program but they really haven't improved it, just started charging for it.
