does this thing perform hardware mpeg encoding if you are capturing from analog sources?
dazzle's product description is worthless....ican't find this info anywhere.
thanks
THIS IS HARDCORE
nope, it converts analog 2 DV so you can cap via firewire as a dv stream (thats y its called a dv bridge) there good, but i wouldntt recommend one unless u have a Mac.
so.... it converts from analog to DV, but does not compress into mpeg?
ok then... so, suppose i have a dv bridge connected to the firewire on my p2-300mhz.... i capture from vcr/cable to dv on my computer.
i would still need to encode it then?
what kind of file format would record on my hard drive?
thanks
THIS IS HARDCORE -
statuspending,
What you might want to look at is a Sony DVMC-DA2 media converter.
It takes the analog input, composite or s-video, and outputs it via
firewire. You can then connect it to your MiniDV camcorder or your computer,
if it has a firewire card/connecter in it. The video is converted in either case
to DV format which IMHO is a snap to re-encode into MPEG-2 files via TMPGEnc.
Getting the analog video into DV format will save you lots of headaches...
BTW, I haven't heard a bad thing about the DVMC-DA2. There have been
issues however with the DV Bridge.
I'm saving my money to buy a DVMC-DA2, for what it's worth.
the dv footage appears on your computer as an avi, which will need to be encoded 2 mpg. beware tho, 10econds of dv footage is about 36mb...
thanks for your replies.
i will have to figure out then where to go from here.
i go from p2-300 to athlon's top of the line in april...
it's about time for a change.
thanks
THIS IS HARDCORE -
Look at http://www.miglia.com for Directors Cut. I considered the dazzle but decided against it. I have only just started using this box and so far so good - it even works well with windows 98FE.
If you are looking at the Sony or Dazzle unit, consider a low-level Sony D8 camcorder with analog-in. The unit will do the analog->digital and digital->analog conversion, plus give you a place to store the huge DV files that you might want to archive.
Ivy Bridge to be up to 199% faster than Sandy Bridge
By deadrats in forum ComputerReplies: 33Last Post: 7th Dec 2011, 12:06 -
Hardware issues in encoding
By videobread in forum ComputerReplies: 3Last Post: 23rd Nov 2011, 09:38 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Hardware Encoding
By jeby1980 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2010, 23:03 -
Software or hardware encoding for project?
By stantheman1976 in forum Video ConversionReplies: 2Last Post: 11th Jun 2008, 15:53
