Dear all,
I have searched a lot but didn't find the right answer to my question? So can someone tell me the differences between
Taiyo Yuden wit printable or the
Taiyo Yuden non printable
regarding the printable layer? Is this printable layer an extra layer which make them (besides printable) more reliable or has the non printable also an 'extra' layer but not printable.
I have also read that the printable layer can cause some problems in the long term and that, if you don't use the layer to print on, you better buy a non printable. Is this right?
I don't print on it. Maybe writing with a good marker. I'm also speaking about CD's not DVD's
Thanks in advance
Is the printable layer a extra one ? I guess it is in a way, but its only very thin. Run printable ones both printed and unprinted with no problems...
If your not going to print onto them dont waste the extra ££ buying printable ones.Not bothered by small problems...
Spend a night alone with a mosquito
A question about Taiyo Yuden.
By wtsinnc in forum MediaReplies: 18Last Post: 13th Jan 2013, 05:03 -
Tayo Yuden Printable and Nero cover design
By alexwick in forum MediaReplies: 5Last Post: 10th Oct 2011, 11:00 -
JVC Taiyo Yuden Blu-ray White Inkjet Printable 4X 25GB BD-R LTH
By xobituaryx in forum MediaReplies: 2Last Post: 17th Jan 2011, 10:25 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29 -
Taiyo Yuden DVD-R - Thanks
By casual-dvduser in forum MediaReplies: 3Last Post: 6th Jun 2007, 03:59
