  1. Something's been bothering me for a while. I've been using DVD Maestro for a while. Every once in a while I have need of subtitles. In the subtitle edit frame, there are options for setting button colors and displaying buttons, but I can't for the life of me figure out how to draw buttons in the subtitles. This would be a particularly useful feature, if it is possible, especially since I often author multi-angle dvds and some of my users don't have angle buttons on their remotes.
    Any information would be appreciated.
    TIA,
    Eric
    Jul 2004
    England
    Its pretty similar to the MENU way of doing it ***BUT*** you have to load in BMP's instead of PSD's and they should be at 720 x 576 as opposed to the menus 768 x 576 - (for PAL, adjust for NTSC accordingly)make the background solid white then in the colours part of the subtitle menu make white transparent then draw your buttons out over your BMP.
    Dave.
    There are 10 kinds of people, those that understand binary and those that dont.
