I just checked out Ahead.com and found they've posted new Nero updates dated August 13th...
I have a Nero 6 package that came with a memorex DVD burner I bought this spring. Does anybody know if I can download and install these updates?
I'd just go ahead and try and see if it will work....
These updates were successfully installed to my 'non-transferable' Nero.
I've had problems with Nero Vision Express authored dvds not playing on stand-alone players. Guess I'll give it another try now. -
Changes from Nero 6.3.1.17h to 6.3.1.20
Release Date: 08-11-2004
New Features
Added support for new recorders
Nero Express:
The user will now be informed if the DirectX™ version needs to be updated for handling MPEG-2 files.
Nero StartSmart:
Support for updated help files has been added
Bug Fixes
Nero Burning ROM / Nero Express:
A Windows XP SP2 compatibility problem is solved
In the expert features of the preferences a localisation problem is solved
Wrong message was shown when an installation was cancelled
New function was added for changing the booktype with several drives
Implemented a workaround for some device specific problems
A problem with the audio plugin manager is solved
Improvement for DVD+VR support on DVD+R9 media was made to determine if a layer breakpoint is set
While opening the setting tab in the expert feature an error occurred
Burning a VCD from a MPEG-1 file failed under Windows™ 95b
Nero Burning ROM:
All controls are now disabled after the burn process is finished
When adding data to a DVD-RW instead of overwriting existing data another media was demanded
A problem with burning VCD is resolved
Fixed a problem that some burnt CD medias were not readable anymore
An unnecessary system reboot at the end of a DVD–VR disc copy process is solved
Audio CD image copy with checked option “copy all subchannel data” resulted in a CD with silence and clicks
Fixed a instability problem when copying a DVD-VR disc
Nero Express:
A problem with a strange title name in Nero Express is solved
When an AAC and a WMA file were added, the slider could not be moved
An error occurred when trying to burn a S-VCD from a S-VCD compliant MPEG-2 file under Windows ME™
A problem with adding DRM protected audio files to Nero Express has been solved
The volume label name of a DVD video compilation is now corrected in case of specific system language
A localization problem under Korean systems in the time track for creating audio CDs is solved
The time-slider in the preview window was jumping back after moving
Fixed a problem in the preview movie player
A multisession CD could not be continued after two sessions
Can’t enter more than only one Korean word in VCD disc name is resolved
A problem with VCD burning under Windows™ 98 SE is resolved
Improvement for displaying Thai text strings on some buttons was made
Adding a video file to a compilation with the add button wasn’t possible
Nero StartSmart:
Fixed a problem with user profiles
Entering a new serial number was rejected with an error
Resolved a GUI problem when switching languages
Nero BackItUp:
Some GUI improvements are made
Nero Wave Editor:
Playback of a WMA file failed when a file was opened the first time
Nero Cover Designer:
A problem that was caused by clicking on the brush tool is fixed -
Tested the update burning DVD-video and CD copy. Works great!
Almost as good as version 17
help me go from 3 VOBs to 1 mp4 :) /as posted in EDITING
By infernali in forum Video ConversionReplies: 2Last Post: 6th Jun 2011, 04:01 -
video overlay, may have posted to wrog forum
By Richpress in forum Software PlayingReplies: 0Last Post: 10th May 2011, 22:28 -
Sorry if already posted : Question about BD and DVD's ....
By tcory in forum MediaReplies: 6Last Post: 24th Feb 2011, 15:11 -
Nero 6 vs Xp updates Mid July 2009 , NO DISC DETECTED
By org74 in forum DVD RippingReplies: 0Last Post: 1st Aug 2009, 13:35 -
sorry if this has been posted
By bams68 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 21:22
