I remember LordSmurf commenting on the magnetic field emitted by this recorder a while bacl. Well mine just arrived and am wondering wether its ok to have it stacked on top of my 9800.. will the magnetics interfere at all?
Not familiar with that note or the unit, but usually the bottom of electronic units are made of steel that effectively cancels out electromagnetic effects. If in doubt, just add a little spacing as the magnetic field is usually limited by distance.
My machine has a distinct magnetic field on it, on the bottom front right side. I saw this on both the DRM1S and my current DRM10SL.
I put the 9800 on top of the DRM10SL. The bottom item in the stack is the JVC recorder.
I would NEVER put this recorder on top of a tv set, on a speaker, or on a VCR. I see this on items from time to time. Another recorder had it, I forget which one at this point.Want my help? Ask here! (not via PM!)
Cheers, rearranged as per description and i'm sure some interference is gone now ..
VHS with interlaced AND rolling FIELDS?
By Heiler in forum RestorationReplies: 22Last Post: 22nd Oct 2011, 18:08 -
converting 60 unique fields ps
By spiritgumm in forum Video ConversionReplies: 98Last Post: 17th Oct 2011, 21:22 -
Can VHS tapes get damaged by HDTV magnetic field?
By Pixelrage in forum MediaReplies: 7Last Post: 16th Aug 2010, 00:22 -
Fields problem
By themaster1 in forum RestorationReplies: 4Last Post: 14th Oct 2008, 19:27 -
Magnetic storage versus flash.
By Xylob the Destroyer in forum ComputerReplies: 13Last Post: 9th Mar 2008, 19:02
