Is there a surefire way to determine the field order of an avi?
I have tried the suggestion of previewing a "deinterlaced" clip in the advanced tab of TMPEGEnc but I can't tell which looks choppier--top field first, or bottom field first. I have also tried encoding clips to SVCD, but they seem identical. Does this mean my source is progressive and thus field order is irrelevant?
All I know is that my source is 25 fps PAL. Is there a program of some sort like GSpot that could tell me whether my source file is top field or bottom field first?
When you press the right arrow keys several times and the video seems like it went back a frame, then you have the wrong field order. If you don't see the back step in the frames, then you have the right field order. If you don't see any back step from either top or bottom field first, then it is probably progressive and you don't need to worry about the field order.Originally Posted by headless chicken
Tried your suggestion Nocarebear...
Both Top field and Bottom Field appeared to go backward!!!
What gives here? -
That has never happened to me before. I don't any other ways to determine field order except encoding a small clip and see if it looks right. If both don't look correct, I don't know what else you can do.Originally Posted by Drakng
That's the way I do it. Find a piece of your source file with lots of side to side motion and encode it both ways. Author both clips and burn it to RW & try it out.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 10:19 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 16:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 21:32
