Hi!
I wanted to convert an XviD2DVD with DVD2SVCD
Everything was going fine till MPlex had to mux the encoded files.
Then MPlex failed, and I don't know what to do...
The logs:
DVD2SVCD:
Code:WNASPI32.DLL 4.71.1.0 -------------------------------------------------------- - 2004.08.10. 9:34:38 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - D:\BitTornado Letöltés\Azureus\Film\Film.avi Initializing finished. Saving Subtitles ini file -------------------------------------------------------- - 2004.08.10. 9:34:44 - Free on drive C: 8646.22 mb - AUDIO Extraction -------------------------------------------------------- Audio extraction finished. -------------------------------------------------------- - 2004.08.10. 9:37:05 - Free on drive C: 8646.09 mb - AUDIO conversion -------------------------------------------------------- -------------------------------------------------------- - 2004.08.10. 11:28:10 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - Initializing finished. -------------------------------------------------------- - 2004.08.10. 17:29:08 - AVI to SVCD Conversion - AVI2DVD ver. 1.2.2 build 1 -------------------------------------------------------- Initializing WARNING! You seem to be using "Norton Unerase Protection" and you want to delete the temporary files created by dvd2svcd. This can cause DVD2SVCD problems. Even though DVD2SVCD deletes the temporary files, Norton doesn't, therefore DVD2SVCD might run into diskspace problems. I suggest that you stop the "Norton Unerase Protection" Service. - Initializing finished. -------------------------------------------------------- - 2004.08.10. 17:29:47 - Free on drive D: 9334.75 mb - Crash Recovery - Restarting from: Video encoding -------------------------------------------------------- - 2004.08.10. 17:29:49 - Free on drive D: 9334.75 mb - Video Encoding using Cinema Craft -------------------------------------------------------- Executing Cinema Craft Encoder. StreamSectors: 4546875788 AudioSectors: 172914896 VideoPAPO: 67754988 ScanOffsetBytes: 266501 SeqAligningBytes: 16937587 DVDBytes: 0 VideoEndHeader: 4 SubtitleSectors: 0 EmptySectors: 238.00 PictureSectors: 0.00 PureMPEGStream: 4289001812.17 Seconds: 7108.68 CalcMPEGStream: 4289001812.17 Frames: 177667 CDSize: 4350.00 Number of CDs: 1 Cut point 4345.00 Variable Settings: Frames: 177667 Anti Noise Filter: Off Passes: 2 Image Quality: 17 VAF file creation: On Video Encoding Mode: Multipass VBR Min. bitrate: 800 Max. bitrate: 8000 Avg. Bitrate: 4826 Aspect Ratio: 16:9 (borders added, encoded as 4:3) ---AVS Begin--- LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL") AVISource("D:\BITTOR~1\Azureus\FILM\FILM.AVI",audio=false) ConvertToYUY2() LanczosResize(720,295) AddBorders(0,140,0,141) Import("D:\DVD2SVCD kimenet\ResampleAudio.avs") ResampleAudio(44100) ----AVS End---- Closing program CCE Max Speed: 1.060 Video Encoding finished. -------------------------------------------------------- - 2004.08.10. 23:10:48 - Free on drive D: 5424.35 mb - Multiplexing Audio and Video -------------------------------------------------------- Executing MPlex. Commandline: "C:\Program Files\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "D:\DVD2SVCD kimenet\MPlex_Muxed_File00.mpg" "D:\DVD2SVCD kimenet\Encoded_Video_TMPGEnc_PAL.mpv" "" -------------------------------------------------------- - 2004.08.10. 23:10:54 - Free on drive D: 5424.35 mb - Determining length of audio -------------------------------------------------------- Analyzing finished. Saving Subtitle Timecodes. SVCD subtitles. -------------------------------------------------------- - 2004.08.10. 23:11:40 - Free on drive D: 5424.35 mb - Multiplexing Subtitles -------------------------------------------------------- Executing SpuMux. Commandline: "C:\Program Files\DVD2SVCD\DVDAuthor\spumux.exe" -m dvd -s 0 "D:\DVD2SVCD kimenet\Subs\hu1-1.xml" < "D:\DVD2SVCD kimenet\MPlex_Muxed_File00.mpg" > "D:\DVD2SVCD kimenet\MPlex_Muxed_File00-subbed.mpg" SpuMux failed for unknown reasons! For details open: "D:\DVD2SVCD kimenet\Subs\SpuMux_log.txt"
MPlex:
OK. SpuMux then fail because MPlex didn't create the file.... It is also interesting that DVD2SVCD didn't stop when MPlex crashed! It continues!Code:INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $) **ERROR: [???] Unable to open file for reading. :shock: :o
So can you tell me why is it unable to open for reading? I played the "Encoded_Video_TMPGEnc_PAL.mpv" (I used CCE, but I did a recovery and the first time I used TMPG and the filename did not change) so it works fine!!!
When I play the audio (Encoded_audio_1.mp2) it works fine too!!
((I also can't understand why it says Norton UnErase is enabled. I disabled it on all my drives... can it be the source of the problem??))
Please, anybody who can, help me!
Thanks very much!!
gorilla
Results 1 to 1 of 1
Mplex.exe help needed please
By lovelylisa in forum Video ConversionReplies: 1Last Post: 5th May 2011, 05:14 -
[mplex] Unable to open file?
By modyouup in forum ffmpegX general discussionReplies: 11Last Post: 12th Sep 2009, 16:29 -
trying to convert AVI to DVD. mplex error. Cannot find .mpa file?
By anarchyx34 in forum ffmpegX general discussionReplies: 8Last Post: 14th Sep 2008, 19:14 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
svcdvd problem, mplex error
By randomtool in forum ffmpegX general discussionReplies: 1Last Post: 26th Sep 2007, 10:49
