I have been trying to convert the DVD -of my cousin wedding- (running time about 90 min) to an AVI. I've tried several time, with the original DVD copied unencrypted to HD as well as converting the mean feature with OSeX into 1 VOB.
In both cases the resulting AVI is about 800MB, however the movie is played in double speed while the music has correct speed. As a result the last 50% there is no movie (endcredits have shown) just a blanc screen while the music continues.
What's happening here???
To me it looks like a regular DVD with 16:9 picture, 25 bps and AC3 sound.
Well the story gets even weirder.
I had already started another conversion and had modified the quick preset to using 'mencoder'. This time according to QT the movie was only (about) 50 minutes and QT indeed did not show more.
For reasons unknown, I then played that very same file with VLC and to my astonishment VLC showed the total movie with NO problems whatsoever!!
Then I used VLC for the former created AVI (the one that QT showed the movie in half the time while the music played normal full time) and VLC had again no problem whatsoever with the movie, it was shown fully just as it should have been!
Ripley's, Believe It or Not?????
Audio & video out of sync
By gaboone in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2011, 22:21 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40
