As we all know burners dont last forever, especially cheap ones like the optorite dd203 that i got last christmas. Its wierd, hasnt even been a year and its already giving off bad burns 3/4ths of the time. The problem is that it gives "Rings" that are off-color, the color of the original disc basically right in the inner edge commonly. Been trying to fix it, went down the line thinking it was software. Used the current nero, a lower version of nero, dvd decrypter, alcohol 120..Still no go. Only gives good burns whenever it feels like it. I dont really want to deal with the hassle, just easier to eat the cost and get a new burner. I wouldn't recommend anyone buy an Optorite, mines dying after less than a year. Ill try to post some photos of examples of these Rings in the discs later on.
Try and clean the lense and see if that helps,wont hurt if its gonna be chucked.
Ive been keeping my pc components in top shape ever since i got the pc. I use about 2 cans of air-duster every few months. Its not dirty, what it looks like is the burner burns, then "gives up" and then goes back to burning. WHY every app i use doesnt speak up and say "Hey stupid, its not burning it right!" i cant figure out, except that the burner is probably telling the app that it is working in fact and burning properly. As you can see by these "Rings", theyre the same color as the unburned portions of the dvds.
In conclusion, its not the Software and its not the media. All i can say is take my example and DONT purchase optorite's hardware.
Heres 6 photos of 4 example dvds that farted. These are ritek G04's, but the same thing has happened with some taiyo's as well.
http://www.photodump.com/direct/LiSASiMPSON/ps2game001.jpg
http://www.photodump.com/direct/LiSASiMPSON/ps2game002.jpg
http://www.photodump.com/direct/LiSASiMPSON/stupidoptoriteburner001.jpg
http://www.photodump.com/direct/LiSASiMPSON/stupidoptoriteburner002.jpg
http://www.photodump.com/direct/LiSASiMPSON/stupidoptoriteburner003.jpg
http://www.photodump.com/direct/LiSASiMPSON/stupidoptoriteburner004.jpg
Dead Mobo?
By Poppa_Meth in forum ComputerReplies: 14Last Post: 20th Sep 2010, 20:17 -
Is ffmpegX dead?
By wwinter86 in forum ffmpegX general discussionReplies: 4Last Post: 23rd Jul 2010, 13:57 -
Dead Panasonic DMRES35V VHS/DVD Burner Combo
By Painasonic in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2010, 14:26 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 06:07 -
who said vhs is dead !
By victoriabears in forum Newbie / General discussionsReplies: 7Last Post: 28th Mar 2008, 12:22
