I use my Sony DV camera with its digital pass-thru feature to capture TV broadcasts. This works greats, but I have to manually turn the software capture program on to start the capture, and thus can’t use this when I’m away from the computer. I’m using Vegas 4 for captures.
Anyone know of a (preferably freeware) program that would allow me to have the capture switch on at a given time (I don’t really need the off part, since I can set Vegas for the duration of the capture). Or another capture program with a timer that would support DV capture. The capture programs with timers that I have used (WinDVD Recorder) don’t allow one to use the timer functions with DV capture, only with tuner cards.
Check out Scenalyzer. At the bottom of the page there is a link to a timer application that might do what you are asking. https://www.videohelp.com/tools?toolsearch=scenalyzer&s=&orderby=Name&convert=&dvdautho...+or+List+tools
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
Capture to MPG on timer
By bolintx in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2008, 18:20 -
NTSC IRE levels and DV camcorder Pass-Through capture.
By edDV in forum Capturing and VCRReplies: 84Last Post: 1st Jun 2008, 17:58 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20
