I am making a backup copy of some of my dvd's as vcd's. I used smartripper to rip the dvd's onto my hd. The audio on the dvd's that I ripped is in ac3 format. I used dvd2avi before with no problem. But for some reason, on these dvd's when i run the vob files thru dvd2avi and have it convert the audio to wav (I always had that setting on) after it does a few minutes of the movie, I get an A.E.! in the info box. I googled it and on 2 different forums, it was speculated that it meant audio error. Is that what it means, or does it mean something else. If it does, in fact, mean audio error, I will have to re-rip them. I never got that before. It only started with these 8. Can someone please tell me what it means?
Not seen that myself, but i'd suggest trying again using DVDDecrypter, i had some issues with smart ripper.
I tried using DVDDecrypter in the past and every dvd that i ripped the audio was out of sync or the video would play too fast. I never had a problem with smartripper. But what does the A.E.! in the info box in DVD2AVI mean?
consensus seems to suggest it's audio error. sure you selected the right audio stream?
http://forums.afterdawn.com/thread_view.cfm/3658
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
