I am trying to back up my 5 disc Beatles Anthology Discs. Each of the five discs have 2 parts, Disc 1 (parts 1 & 2), Disc 2(parts 3 & 4), etc.
What I would like to do is back up the first part of each disc including the menu and extras only, and then back up part 2 with no menu or extras on a separte, second dvdr. In other words I would like to put the original disc 1 on 2 discs with the menus, extras, and part 1 on one disc and part 2 only on disc 2. Therefore I would need 10 discs to backup the 5 copy original. I hope I am making myself clear. Can anyone recommend a software program that will allow me to back up using this method. I normally use DVDShrink/DeCrypter but the video came out really crappie when I tried to put the whole disc on 1 DVDR. I would really appreciate some advice here guys, thanks a million.
Thank You,
GolfNut -
Try using vob blanker, it does exactly what you want it to do.
The program is free and relatively fast, about 10 minutes or less
to process. It shows you how much space you are using after you
clear up what you don't want, and if it's under 4.3 gig, just burn
your new files, no need to process any further - no loss of quality!! -
Jetfan thanks for the reply. So far I have been able to process part 1 with menu to disc 1 but can't seem seem to get part 2 of disc 1 to back up properly, either without or without the menu? I will keep trying, really wish there was a good guide. Thanks again for your help.
Thank You,
GolfNut -
Originally Posted by golfnutNot bothered by small problems...
Spend a night alone with a mosquito -
Got VobBlanker to work guys, thanks a million to all those who replied to help me. Have a great day.
Thank You,
GolfNut
Easy Question.. Convert mkv to DVD9
By WareISChris36 in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2011, 15:22 -
How to copy DVD9 with subtitle & Burn it in DVD-/+R or DVD9
By prithvi in forum Newbie / General discussionsReplies: 15Last Post: 19th May 2010, 11:37 -
DVD9 to DVD9 2 angles layer break problem
By JoeBolden in forum DVD RippingReplies: 4Last Post: 14th Jul 2009, 19:17 -
DVD9 Iso to DVD5 question
By winman42 in forum DVD RippingReplies: 4Last Post: 13th Sep 2008, 14:12 -
having trouble backing up dvd9 to dvd9
By Chunking in forum DVD RippingReplies: 9Last Post: 13th Oct 2007, 20:34
